Wyse terminal on AccuScore Plus
  • Wyse terminal on AccuScore Plus
    Thanks for reading my post. Our Wyse 520 terminal went the trip and our supplier does not have any. What other Wyse terminals will work so as we can use our official AccuScore Plus keyboard. Or, has anyone had any luck with using a dumb terminal program on a computer to emulate and work with the AccuScore Plus? Again, thanks.
    Howard
    We went to a Wyse s30 Thin Client to replace our terminal. Just need a plain flat screen monitor and it comes with standard keyboard and mouse. Configure it to VT320 and your good to go.
    Good luck
    Chris
      Chris, thanks a million. Will my keyboard work with the thin client or should I get a keyboard too? And, I see the serial port is a db9, would I use a standard adapter from db 25 to db9? Thanks again.
      Howard
        Chris, thanks for taking the time to talk to me on messenger. We ordered a thin client with keyboard. Again, many thanks.
        Howard
          Good deal Howard. Let me know if you need help configuring it. It took me an hour to figure it out, but it works great.
          Chris
          Pins getting gouged
