Error code 199 LCD R
  • Error code 199 LCD R
    Hello guys.
    Need help anybody knows what is this error #199 LCD R for new HD bes X scoring? i am trying to reboot my HD or 3Qt then this error came out..
    Appreciate your Help.
    Kennedy, I've moved this out if the Technical Reference forum for you because this is a question, not technical reference material.
      This is either a problem with the even lane touch screen or the associated cabling. Try swapping the touch screens first
      Regards,
      Billy T
      bthompson@qubicaamf.us
      Pins getting gouged
