Accuscore XL CPU
  • Accuscore XL CPU
    I usually use a company GEI Electronics in Spartanburg S.C. but there phone is disconnected, are they still in business or does someone have another place
    that repair.
    I repair them. I'll PM my details if interested.
    jim8230
    Detector Rod Adjustment
    The New Brunswick NXT
