upgrade accu+ to Conquerer, Flatscreen Converter issues
  • upgrade accu+ to Conquerer, Flatscreen Converter issues
    I am looking at used Qubica scoring as an upgrade from my accu+. Found out Evolution converters need different plugs. Can we rewire 9 pin plug wires of Qubica into flat ribbon cable plug end currently used in my converters?
    Are you looking to upgrade the scoring system or just convert to flats?
    Detector Rod Adjustment
    The New Brunswick NXT
