Screens Black Out
  • Screens Black Out
    Pair of lanes you push reset buttons screens black out. 19th frame you throw spare and say 9 machine automatically resets of course screens black out. They do comeback on after few seconds though any ideas.
    Accuscore Plus scoring
      We have a pair that blacks out intermittently now and then, a cold start on the cwc takes care of it. But, we have not experienced any of the other things you mentioned.
      Howard
        Check the power supply - make sure it's 5VDC +/- .5V.
        Detector Rod Adjustment
        The New Brunswick NXT
