Boss Advertising
  • Boss Advertising
    Hi,
    What's the method and graphic requirement needed to get advertising on the screens for Boss scoring system? We've looked in to it but unable to suss it out, tried a few different things but got no where.
    Cheers
    I believe it is 640x480x256
    Regards,
    Billy T
    bthompson@qubicaamf.us
      You can use MS Paint to create graphics however they must be at a 640x480 resolution and saved as 256 bitmap image files
        Many thanks, do I need to save the file in a particular location for the program to recognise/load up the graphics?
          As long as the files are saved on the computer locally all you should need to do is navigate to where the files are kept in the video merchandising in Boss and import them into the software
          Broken key
          Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
          Anyone wanting to have a guess at
          A) Which...
          MONITOR COLOR ISSUE!!
          Pin spot is off
          4" PVC BOW EXTENDERS
          As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
