Accuscore Plus
  • Accuscore Plus
    7150 chassis right monitor scramble or whatever you wanna call it. After few attempts it'll work. Have evoulution converters also changed that same scrambled monitor. It's not my center it's a center I help at when needed well here I am they said changed chassis same result it communicates all that but right monitor scrambled like. They think it's the ribbon cable I have same scoring since day one they came out and never had a bad ribbon cable not saying that's not the problem . I still think it's the chassis. any help from anyone " Jon" Thanks
    That's usually in the chassis, specifically the video circuit. I've seen these before. The odd thing here is it will work after a few attempts. Does it stay good once it's not scrambled?
      Jon:
      Yes it stays good I just left on the color is ugly compared to left lane flat panels like I said but works. When turned off start all over again trying to get to come up to the Accuscore Logo
        Do you have the video splitter box? smaller box next to scoring chassis. I had same problem back in the day, and it was the gold box. if no spare try swapping it with another pair. I used to rebuild them by replacing some transistors. but its been a couple of decades since I did.
        Later Chief
          No splitter box.
            Originally posted by Scooter View Post
            Jon:
            Yeah, the CWC has a problem. Eventually it will get worse. I had one of these in the shop a few months ago.
            MONITOR COLOR ISSUE!!
            Pin spot is off
