AMF 90/XL Scoring Problems.
  • AMF 90/XL Scoring Problems.
    I have a problem with the scoring on 2 lanes sharing the same camera. The scoring is inaccurate. The most common problem is when a strike is scored and it comes up with a 9. The cameras are checked every day and these lanes don't look any different to any of the others. Any thoughts?
    What scoring do you have?
    Regards,
    Billy T
    [email protected]
      Our scoring system is BES X.
        both lanes score 9 on strike? I would swap camera and board with another pair that is working fine and see if problem follows
          I have already done that.It made no difference. Lane 10 sometimes scores all over the place and seems to right it's self. Very inconsistent.
            I had problem with scoring here , replaced wires from camera board to 6 box , problem solved , my problem was with constant cycling(at random intervals),
              Confirm that SPEC 19 is set, and SPEC 12 is 0
              Regards,
              Billy T
              [email protected]
              MONITOR COLOR ISSUE!!
              Pin spot is off
