AccuScore Support
  • AccuScore Support
    I heard a rumor that Qubica is no longer going to support/refurbish AccuScore equipment. Has anyone else heard one way or another?
    My abilities are only limited by those who try to test them.
    We received a mailing indicating that. I do not remember how long ago we received it.
    Howard
      Pretty sure that's correct. I know they phased out BOSS and XL or will versy soon.
      But I haven;t phased out anything. PM me if you need something repaired.
        We are no longer able to provide technical support for scoring and management software, or provide extended warranty. Rebuilt components will continue as long as parts/components are available
        Regards,
        Billy T
        [email protected]
        MONITOR COLOR ISSUE!!
        Pin spot is off
