AMF Communications Connector
  • AMF Communications Connector
    Good evening. I've been tasked to replace some connectors at a local bowling alley and I'm trying to find a PN for them. I've been in the communication industry for over 30 years and have yet to see anything like this. Hopefully someone will recognize it. Thank you. Phil
    Is that the cable that plugs into the MCU? Per Ted's reply in another post, it is called an SDL connector. I was troubleshooting our MCU recently and had a "what the heck is this?" moment when I checked the cabling.
    http://www.bowltech.com/forum/pinset...u-installation
      Holy Moses! Thank you DBZodos! You've unlocked the last piece of the puzzle! I checked out the thread and you are correct, it's an SDL connector. In the process of locating a TE or Amp PN, once I find it and pricing I'd like to add to this thread just in case someone else may have the same issue...Cheers! Phil
      Qubica BES-X Lane Advertising
      Ball Damage at my wits end
      GS-X table bolts/stud
      Other that...
