Accuscore Monitor Error
  • Accuscore Monitor Error
    Can some recommend how to restart or return lanes to normal operating scoring at start up? Been having an issue with Monitors on only 1 pair of lanes. Lanes are only come up with static like squiggly lines, almost like blurred out, this occurred after a power outage. Any suggestions????
    Move the CWC to a working pair to see if it's the CWC or a monitor issue. I repair CWC's, if you're interested shoot me a PM.
      We use the Evolution upgrade converters with flat panel tvs. We have that happen on one pair, always the same pair. A cold start of the CWC usually clears it up for us.
      Howard
      MONITOR COLOR ISSUE!!
      Pin spot is off
