Advantage Back Office Issue
  • Advantage Back Office Issue
    Hello All,
    I don't know if Deb still lurks around here, but I have an issue with my back office computer. Did a warm reboot (sync;reboot) this morning, and now at my "xenix386!login:", when I type and enter "adv" (without quotes of course), instead of taking me into the Advantage Back Office screen, it comes up with:
    Welcome to SCO XENIX System V
    from
    The Santa Cruz Operation, Inc.
    Then back to
    "xenix386!login:" (without quotes)
    Have not tried a cold boot, but will when we die down. In the meantime, ant suggestions??
    TIA,
    Leyton
    Leyton at Tahoe
    Any takers??
    Leyton at Tahoe
      deb
        Thanks Kanga, got her contact info. But noticed her last activity was 3/19. Anyway, did a cold boot and all is good again. Wish I knew what caused it though. Thanks.
        Leyton at Tahoe
        Bind in deck hook linkage
        GS-X table bolts/stud
        Other that...
