Miss com on XL
  • Miss com on XL
    Hi,
    Since saturday my backoffice is off !!!
    AMF guy comes and repair it, he copy all system on a new hard disk and it was good.
    But now I lost communication with all scorer at any time !!!!!!!
    I try to put CPU of lanes 11/12 on 1/2 to see if it was it, but the problem exist again.
    AMF in France tell me that is normal !
    Also since the repair, when i want to see a daily report (for exemple Monday 7 March 2005), all time was wrong! The last lane cashed wrote 7:41PM or it was at 01:41AM ?????!!!!!??????!!!!!
    Please help me.
    Re: Miss com on XL
    Barouf,
    It sounds as if the windows clock wasn't set to the proper time. Although I don't know what version of Boss you are running, if it's anything recent (9.0 or higher), changing the clock will activate the security feature, and you will need a new unlock code from AMF.
    Without knowing the full picture...that's a guess from me.
    In regards to the loss of communication to the scorers, check to make sure that your hub is working properly. Try cycling the power to the hub as well.
    Fever
      Re: Miss com on XL
      My system is not BOSS, it's an old accusdesk.
        Re: Miss com on XL
        Accudesk and a BO?????????? Something wrong with this picture.
        Maybe an Accudesk XL?
          Re: Miss com on XL
          12 lanes with XL
          1 BackOffice Accudesk
          1 terminal Wyse
            Re: Miss com on XL
            Maybe the BO software was for Advantage. Do you have the IP on, IP off floppy disks?
              Re: Miss com on XL
              How to know the config ?
              In france AMF is so bad !!!!
              They doesn't want to give you any diagram or script to re-config your system !
                Re: Miss com on XL
                  Re: Miss com on XL
                  I agree with Deb, sounds like you have an Advantage B.O. system.
                    Re: Miss com on XL
                    We look, it's an AMF Advantage BackOffice, 12 lanes in Accuscore XL you are link with a "LAN", and one terminal WYSE to put on/off lanes.
                    We repair the problem for communication, it was the CPU of 5/6 ! (I don't know why !)
                    We have just the problem for the daily report.
                    When I want to look a report for the 1st March 2005, the system write a bad hours for the last lane cashed and the amount isn't good !
                    Please help me !!!!
                      Re: Miss com on XL
                        Re: Miss com on XL
                        I've try with "date", the time and date is correct. I'm actually open I close since one hour and I will try with "asktime" and answer you if you gived me the good answer.
                          Re: Miss com on XL
                            Re: Miss com on XL
                            YOU GO, DEB! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                              Re: Miss com on XL
                              "date" and "asktime" gived the same results ... and give me the good date and hours ...
                              Broken key
                              Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
                              Anyone wanting to have a guess at
                              A) Which...
                              MONITOR COLOR ISSUE!!
                              Pin spot is off
                              4" PVC BOW EXTENDERS
                              As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
