ACCUSCORE+ FRONT DESK COMM CABLES PART NUMBERS
  • ACCUSCORE+ FRONT DESK COMM CABLES PART NUMBERS
    Can anybody give me the part number and or pin outs on the following amf accuscore + cables
    1- comm cable from the front terminal to the liu
    2- liu home run cable, from the liu to the octopus cable.
    3- octopus cable
    4-rj 11 cable from the home run box to the blue adapter.
    5- the blue adapter
    6- from the blue adapter to the computone board.
    we really could use these so we can either order them or get them made ASAP. we have been without liu comm for 2 weeks and need to fix a problem
    anybody here have that info they would like to share with me, i would deeply appriciate it
    deane
    Re: ACCUSCORE+ FRONT DESK COMM CABLES PART NUMBERS
    1-rs232 cable 231-001-080
    2-liu cable 231-001-042(150 ft)or 231-001-082(100ft)
    3-octopus cable 290-002-040
    4-rj 11 cable 290-001-041
    5-25 pin male adapter 290-002-046
      al, i don't soppose you have the pin outs for them do you
      Bind in deck hook linkage
      GS-X table bolts/stud
      Other that...
