WG Monitors - Changing Power Supply
  • WG Monitors - Changing Power Supply
    Does anyone out there have a step by step to safely change a power supply on a WG monitor? I would like to keep a copy for the pinchasers...
    Re: WG Monitors - Changing Power Supply
    I am looking for a power discharge process for the suction cup to aviod a zap!
    I have not changed one yet; however, lane 6 will be due shortly.
      aligator clip, wire and a long blade screwdriver. Just attach the wire to the clip and tape the other end to the screwdriver(securely) Attach the aligator clip to a good ground and be sure to touch the ends of the HV cable several times.
      Mark
      (919) 757-1789
        ratchetwrist... worked like a charm. Thanks!
        Help-broken Part
        Greeting all.
        Thanks for looking.
        Bolton454
        Pin Damage
        Making TDM's adjustable.
        1:1 shaft wear
