accudesk help
  • accudesk help
    installed accudesk to our accuscore plus it doesn't seem to be communicating. It allows us to put center name comm light flashes 4 times every 30 seconds or so. Comm light on lane flashesonce every 30 seconds or so any suggestions. Thanks in advance
    Might be a bad accudesk interface box - any comm flashing at the scoring cwc's?
      Installed?
      Was there no desk before?
      The eprom in the CWC for the Accudesk is different from the eproms in the back. Check this first.
        Each pair of lanes CWC flashes once EPROM in front desk is 116 EProm and lanes 532's. This is a new front desk. Is there something we should do to get it out of stand a lone.
          Try clearing all the data out of the rear CWC by pressing the reset buttons for 10 seconds from the terminator cable back toward the front desk
          Then clear the front desk by pressing the button for 10 seconds and inputting all the data.
          There is a command in the Accudesk to put lanes in service - but it is usually not needed
            http://www.bowltech.com/forums/showt...cion-Key-setup
            Make sure the Wyse terminal is configured correctly
              I'll double check tomorrow, but if I recall correctly - V5.32 doesn't work properly with V1.16 at the desk. If this proves to be the case, you have to use V4.24 in the scorer CWC's. You'll lose two players per lane (6 frame grid), but it will comm. OK with the desk.
                OK - I verified that 5.32 doesn't comm. with SAD 1.16 at the desk. To get comm, you'll need to change the software in the scorers to SAS4.24.
                I'm sending you a PM.
                  We did this does the same thing we changed EEPROMs to 421 did this and get the same thing
                    I have SAD1.16 on my AccuDesk and test cwc's with version 4.24. You having low boys with splitters using 2 keypads need SLB4.24.
                    Super Bowl Funday!
                    Qubica BES-X Lane Advertising
                    Making TDM's adjustable.
