Purge the desk
  • Purge the desk
    Have perfect desk front desk trying to send leagues out this am sent out two when went to send out third league it said max leagues open is 10 only problem is had only 2 open anybody have this issue before thanks in advance Jacko
    Same problem here, started 2 weeks ago. I did a front and back office restart, with no luck. I am having them do a warm reset on the CWC's this morning. Any other suggestions will be most appreciated.
      Look for the purrfectdesk.ini file and see what is in the positions of leagues 1 -10. Save a copy of the file in a different location, then erase info on those lines and restart everything.
      Loading...
      The New Brunswick NXT
