Accuscore Plus Front Desk w/Accudesk Rebooting Issue
  • Accuscore Plus Front Desk w/Accudesk Rebooting Issue
    I have Accuscore Plus scoring with Accudesk, during league play it runs fine, but during open play, the front desk reboots itself quite often in the night. It will ask me for name of center , how many lanes etc. all the way to input date and time, I know the system is not Y2k only goes to 1999. What could be the cause of this issue, I will be changing the front desk to Purrfect Desk this summer, but for now need to know what is causing this issue.
    Thanks
    we have the same set up. We enter a date prior to 1999 that aligns the same days and dates of the current year. Ours sometimes seemingly does a reboot in the night and the date changes to the first of a month, not always the same month. It does not go all the way back to center name, etc. You might try removing the eprom card from the desk CWC and put it back in. Might be a dirty contact. Shut CWC off before you remove the eprom, of course.
    Howard
      When it asks you for a time & date, just hit return & let it default. If it's randomly rebooting, I suspect a failing CWC that's resetting itself.
      Qubica BES-X Lane Advertising
      Ball Damage at my wits end
      GS-X table bolts/stud
      Other that...
