reflector guard
  • reflector guard
    reflector guard for Qubica.
    Re: reflector guard
    I cut up some foul lines and put them on the machine side to keep the lane machine cord from catching.
    If a reflector ever gets hit by a ball then I'll put those on too!
    Now You've Gone And Done It!
    See What You Went And Did!
    What A Thing To Go And Do!
    MONITOR COLOR ISSUE!!
    Pin spot is off
