Vector LCD touchscreen calibration
  • Vector LCD touchscreen calibration
    How do I calibrate our LCD touchscreens. I cannot find anything in the books.
    the touchscreen is divided into 9 sections. starting with section 1 on the bottom left. the code to get to the calibration screen is 939393. in other words, top right side of screen (9) and lower right of screen (3).
    <---- You are getting sleepy, very sleepy. When you wake-up you will want to bowl more. . . .
      lawrence is correct with the numbers but make sure you tap the screen 9-3-9-3-9-3 until it goes into calibration.
      The New Brunswick NXT
