HDMI Capture Frameworx with Evolution Converters
  • HDMI Capture Frameworx with Evolution Converters
    Hope this is the right spot for this question. I'm trying to capture the output of Brunswick Frameworx scoring through Evolution Converter boxes, and use it to stream my event to the internet.
    1. I seem to be able to capture other hdmi sources
    2. I can split the hdmi signal from the converter box to multiple off the shelf televisions
    3. Nothing shows when I connect to the converter box
    I assume this might this have something to do with the 800x600 output that I am getting from the convertor box combined with my bottom of the barrel capture card? If anyone has some experience with this I would appreciate your advice!
Detector Rod Adjustment
The New Brunswick NXT
