As-k 90 to as90c
  • As-k 90 to as90c
    Are the boards compatible from the as-k 90 and the as 90 c?
    Which boards? AC, CPU, IO?
      All three? I can't find part numbers for what the as 90 c is supposed to use I have the part numbers for the ask 90 but I'm looking particularly looking at the CPU and IO boards knowing about the ac would be great too
        turned out that it was an as90c system not an ask90 that my manuals said that they were all consoles up and running now
          Thanks for getting back with us with the update.
          Mike Wilson
          Bowl-Tech Inc.
          Detector Rod Adjustment
          The New Brunswick NXT
