Vector scoring
  • Vector scoring
    When replacing the keypad control cable do you have to remove any part of the ball table that the wire goes thru to the keypad. My first time doing this . This is on the vector scoring system.
    If you are replacing the cable from the keypad to the server on the back wall, yes.
    There are 4 bolts under the table, that hold the table top to the metal base.
    The console cable wraps around a post or two in that metal chamber under the table.
    You also may need to unbolt the ball rack base from the floor, for easier access to pulling the cable.
      Ok thanks for your help
      Oil in gutters
      C1 Pinout drawing
      Finished the C1 drawing.
      Thanks Felix.
      If you see any...
