Brunswick Vector 5.28 scoring
  • Brunswick Vector 5.28 scoring
    Just installed Brunswick Vector scoring in a center. Its a used system and the scoring computer on the curtain wall is set up for 4 lanes, I need to set it up foe 8 lanes, does anyone know how to do this? I think the scoring came from Blanchard Ok.
    You should be able to configure the slave from the keypads up front.
    Use the /VECTOR command to access the menu.
    You can setup the slave number (if needed) and the lane numbers.
    Detector Rod Adjustment
    The New Brunswick NXT
