Frameworx CCD scanner tester (info)
  • Frameworx CCD scanner tester (info)
    I have a transformer overheating on my ccd tester. My local electronics store could not find info on the transformer. Does anyone have the voltages associated with it ? They would like incoming and outgoing if possible. A part number would also be a help. Thx !! Frameworx running 8270s
Broken key
Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
Anyone wanting to have a guess at
A) Which...
MONITOR COLOR ISSUE!!
Pin spot is off
4" PVC BOW EXTENDERS
As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
