as 90s
  • as 90s
    I have a lane that will give you a score without bowling or if you break the beam on the ball detect it will also give you a score. Any ideas thanks.
Broken key
Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
Anyone wanting to have a guess at
A) Which...
MONITOR COLOR ISSUE!!
Pin spot is off
4" PVC BOW EXTENDERS
As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
