MONITOR ISSUE WITH THE VECTOR PLUS SCORING
  • MONITOR ISSUE WITH THE VECTOR PLUS SCORING
    I HAVE A MONITOR THAT FLASHES WHEN ON. TRIED CHANGING THE VIDEO BOARD WITH NO RESULTS ALL I AM GETTING IS A GREEN DOT SAYING THE MONITOR IS ON AND THEN IT THE GREEN DOT STARTS FLASHING. ALSO CHANGED THE BRIDGING TAP OFF AMPLIFIER BOARD AND STILL WAS UNABLE TO GET MONITOR TO SHOW. ANY SUGGESTIONS OF WHAT I CAN DO TO FIX THE ISSUE.
    Quick check = Get a spare VGA cable and connect to the other control box on the same pair.
    This will determine if the problem is in the box, or the monitor.
    Triple output power supply could be bad, or video board going from cat5 to VGA.
    You can swap with another lane to test, if you dont have a spare.
    Neither of those have the lane address switches on them.
    Detector Rod Adjustment
    The New Brunswick NXT
