As80/90 Conversion
  • As80/90 Conversion
    Hey everyone we got the Brunswick 80/90 Conversion and having a problem with it getting signall to the LG Smart TVs is there anything that we are missing to get it where it will come up anything will help thanks
    Make sure that if you are using the Evolution conversion boxes that you have the proper lane number set in the dip switch bank.
    Detector Rod Adjustment
    The New Brunswick NXT
