Foul
  • Foul
    Scoring a foul continually with foul lights off
    Daniel Mills
    What scoring system and foul lights do you have?
      We have the old Bruns Astroline foul lights here and I have had trouble in the past with the new pins solenoid staying energized. Turned out to be the foul light board even though it wasn't energized. I'd try swapping out the PCB with a good one and see what happens.
        We have Brunswick as90, Zot foul lights . Unplugged foul light data line to prosessor. Still put up fouls. Changed prosessor, still put up fouls, then quit scoring ? Doesn't do it continually, but quite a bit. Started with other mechanic, foul data line damaged from cover, cut wires before league ,still scored fouls.
        Daniel Mills
          Have you swapped out the CPU board up front to rule that out?
            Correction : no foul related problems, but stopped scoring in 3rd game of league. This after changing ccd prosessor. Today, adjusted voltage from 5.06 to 5vdc and disconnected all foul light connections. Bowled several games with no issues. Will wait and see .
            Daniel Mills
            Oil in gutters
            C1 Pinout drawing
            Finished the C1 drawing.
            Thanks Felix.
            If you see any...
