AS90 Scoring/Ball Detect Issue(Similar to post below)
  • AS90 Scoring/Ball Detect Issue(Similar to post below)
    On one pair of lanes, the odd lane will not score but the even lane will. I have switched processors, ball detectors, and ball detect wires. Lights come on on ball detectors like normal. When I hook up the CCD Scanner, it does not show pins when I throw a ball but when I switch to the align l. side and align r. side the live feed shows the pins.
    Any help would be great. TIA.
    Try replacing your 44/144 and 0 degree switches on the pinsetter.
      Ball detect is not working on odd lane. When I hook up the ccd processor, it shows open and close on the even lane when I pass my hand through the ball detector but just stays open on odd lane as I pass my hand through it. I have tried 3 different ball detect cables but it does the same thing. I have switched out the scorer box but it still does the same thing. I can't figure out how to find the problem so I can't fix it.
        Figured it out. 0° switch was not working so it would not register the ball detect since it was not closed. Replaced the switch and it works now.
        Oil in gutters
        C1 Pinout drawing
        Finished the C1 drawing.
        Thanks Felix.
        If you see any...
