frameworks overhead monitors
  • frameworks overhead monitors
    scoring is oversized and graphics are scrambled. have changed all boards in primary console and it remains the same. Any ideas?
    Is there someway to change/adjust the aspect ratio of the monitor itself? Like when trying to get a program to fit on your laptop screen ......
      not that I know of.
        Which overhead monitors do you have exactly?
          Are both monitors of the pair showing the same problem?
          If not, swap the video feed to see if it moves to the other monitor.
          This can rule out either the scoring, or the overhead monitor.
            48 inch samsungs. both monitors on pair have same issue. if I shut off exciters on the pair and then send audio video to these monitors, it will make the screen print normal size. sometimes it takes a couple times of doing this to make this work
              It looks like you do not have Frameworks monitors, you have flat screen TVs with a converter box. I would swap that to another pair, and see if the problem moves.
                I have changed out the frameworx lcd interface and the problem remains
                  If you have changed all the components in the system, Then a short in a cable or bad connector some where......
                  Upgraded Motor Contactor
                  C1 Pinout drawing
                  Finished the C1 drawing.
                  Thanks Felix.
                  If you see any...
