ZOT
  • ZOT
    Anyone know of a electronic repair company that repairs the zot time delay plus? Growing tired of waiting 4 months for an exchange. Thanks
    Daniel Mills
    Get a hold of Mike at Bowling Scorer Technology. He said he may be able to help you out if you send him a picture of the unit. https://bowlingscorer.com/
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
