As-90 Wiring diagram
  • As-90 Wiring diagram
    Hi-
    Does anyone have a diagram of the wiring to install
    as-90's?
    Thanks-
    Ran
    Re: As-90 Wiring diagram
    rhanks,
    What exactly are you installing? Certain components, the whole scoring system (consoles, front desk, cameras, overheads, data processors, pinsetter switches) I don't believe there is one 'master' wiring diagram to do this, you will need to get your hands on an as series scoring service manual. This won't exactly tell you how to do it but will tell you what each wire should look like and where it plugs into. If you have no experience with as series scoring you are going to have a lot of fun to put it in if it is a new install. I just went through replacing a lot of comonents and upgrading to a command network system and still have headaches [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
    Qubica BES-X Lane Advertising
    Ball Damage at my wits end
    GS-X table bolts/stud
    Other that...
