CMOS Maintenance Board help
  • CMOS Maintenance Board help
    We just got a CMOS Maintenance board and I installed in one of the lanes. I got to boot off the card. So I followed the direction which said to remove it and see if the Lane boots up with out it. No joy. So I reinstalled the cmos board and now it's not booting up?? Any suggestions.
    Re: CMOS Maintenance Board help
    I'm assuming you are running Frameworx. Sometimes the slot you plug it into doesn't work, or is dirty. The instructions say to plug it into the first slot, but I have put it anywhere on the motherboard with no problems. It could be that your hard drive is bad. Is it a new one? Are you sure it is formatted correctly? I have run into situations where for some reason I had to leave the CMOS card in the console for a day or two, then when I took it out, everything was fine. I have seen this more than once!
    Also, and I suppose this is a dumb question, but did you shut down the system before you took out the card?
    Give these a try and let me know if it works.
      Hi Jerry,
      It's possible about the hard drive. Right now we have 3 sets of lanes down with bad scorers. I still new to all this and when we originally started helping, we replaced about 4 motherboards. At that time I didn't know about the cmos maintenance board. I followed the directions about installation of the board. Secure power, install board, then repower unit. After it booted the first time, shut down power, removed board then restarted. Scorer didn't come up without the board so I reinstalled it and tried again. I tried it in various slots also. Previously I had checked the batteries on lanes that are down and found memory batteries were bad and replaced them. That's why I had them buy the board. Right now I've left the board and I'm going to have reboot the whole system. And see what happens. Thanks for help.
      Tim
        Tim has it,Most likly battery or hard drive. Ive found that the hard drive brunswick uses are garbage. If it is the battery Radio shack will save you.
        Chris Doughten
        Lodge Lanes, Belleville Mi
          I saw where they have come out with a flash drive adapter now to replace the hard drive. Wish they had that when I still worked on frameworx. Has anyone tried it yet?
            usually if you can boot with cmos and not without the problem is the batt on your motherboard. unfortunately you may need a keyboard and monitor set up so that you can pass the break in the boot process that can occur after changing the battery. when I was in Muskegon, Bill Jager showed me a setup using an old tandy keyboard and a monichrome video card and monitor that allowed you to see the boot process and make the appropriate entry, but unfortunately I have been unable to duplicate this back at home, and have never gotten a reply to any emails asking him for help finding the appropriate parts. Unfortunate that big B doesn't sell this as a troubleshooting tool, as this would be a big help in finding what board is causing an lgp to fail to boot..
            <--- Start 'em young!
              I got another question about this. I pull up the maintenance window on one of the other lanes and checked the software version on it. It say 4.06, the maintenance board I got said was version 7. Would this possibly cause problems with it booting up?
                4.06 is probably the scorer software version on the hard drive, 7 is the maint board version
                  Usually if it fails to boot up the hard drive is at fault or MAYBE the power supply. Does the power supply fan turn on.?
                  The older the part, the STRONGER it is.
                    Has far as I know the fan is running on the power supply. The question is would I be getting the same problem between 3 different sets of lanes? I swapped the complete assemblies between lanes and got the lanes running by doing that. So that would eliminate the power supply as the problem I would think. But that's why I'm on here you guy have been working on these things alot longer then I have. I appreciate the help by the way.
                    MONITOR COLOR ISSUE!!
                    Pin spot is off
