No Foul Indicator To Scorer
  • No Foul Indicator To Scorer
    I have 5 pairs where the F for foul doesn't display on the overhead monitors when the foul unit signals that a foul has occured. Need some help.
    Re: No Foul Indicator To Scorer
    Aha! One of those split foul issues. The AMF machine needs a 12 vac signal to go through a foul cycle. Brunswick scorers want just a switch closure. With the AMF machine installation, Brunswick is supposed to provide a relay adaptor to give their scoring a switch closure instead of the voltage.
    If the machine is going through a foul, then the Brunswick relay adaptor isn't installed, wired right, or the output not tied into the scorer interface.
    Qubica BES-X Lane Advertising
    Ball Damage at my wits end
    GS-X table bolts/stud
    Other that...
