IC Switch Cluster
  • IC Switch Cluster
    Helping a friend fix a scoring problem on AS80 yesterday, had a 44/144 switch that had gotten messed up, he said he had some more switch clusters, and handed me one off the old Bruns IC scoring. They had 6 micro switches. That was a real PITA of a system when you had a problem!
    Brent V
    Re: IC Switch Cluster
    The real PITA was the Astro-Gold Crown that had 11 switches on the cluster.
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
