distibution board shorts out
  • distibution board shorts out
    Replaced it with known good and it blew. Replaced wiring from slave to board then trieds known good board . Board blew again. Is it possible slave is causing this? Any other ideas? Thanks
    the slave can cause the board to short. distribution board gets its power from the slave. the cable from the slave to the distribution board has to be disconnected from the slave before connecting it to the distribution board. i have shorted boards before by trying to connect the cable while it was still connected to the slave. especially when you go to screw in the connector and the screw driver creates the short.
    <---- You are getting sleepy, very sleepy. When you wake-up you will want to bowl more. . . .
    Broken key
    Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
    Anyone wanting to have a guess at
    A) Which...
    MONITOR COLOR ISSUE!!
    Pin spot is off
    4" PVC BOW EXTENDERS
    As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
