42" flatron lg upper monitors
  • 42" flatron lg upper monitors
    Does any one know how to get power saving mode off of thes tvs i have 16 lanes and 8 went out
    We use that same monitor. What do you mean they went out, is the power led in the lower right front off completely or yellow! Can you turn them on manually using the remote control or by the power switch on the back panel? If a whole bank of 8 went out I would suspect a circuit breaker. Make sure you have AC power to the outlets.
    DJ
      Did you ever figure out the problem?
      DJ
      Qubica BES-X Lane Advertising
      Ball Damage at my wits end
      GS-X table bolts/stud
      Other that...
      1:1 shaft wear
