0 degree switches
  • 0 degree switches
    I am helping an center with scoring issue. They have 82/30 with AS 90 scoring. They have two lanes that the 0 degree switch is showing open on the ccd scanner. The switches are mounted with the 144 switch all the way to left of shaft they are mounted on. The 44 degree switch is mounted to the right along with the 0 degree, i think. is that the correct way it is don on these machine or am i looking in the wrong area or switch sequence.
    thanks
    .Coby
    Coby
    ANYONE WHO HAS NEVER MADE A MISTAKE HAS NEVER TRIED ANYTHING NEW
    Wrong forum.
      was not sure whrer to put it, looked like the right place to me, but it is in the wrong one, can someone move for me. thanks
      Coby
        You had it in the AMF Scoring forums but you were asking about AS-90 scoring which is a Brunswick scoring system.
        I have moved it for you.
          I am helping an center with scoring issue. They have 82/30 with AS 90 scoring. The 44 degree switch is mounted to the right along with the 0 degree...
          That configuration sounds like they are on 82-70's...
          jim8230
            Jim you are correct, they are 70,s
            Coby
            Qubica BES-X Lane Advertising
            Ball Damage at my wits end
            GS-X table bolts/stud
            Other that...
