Classic Scoring won't load and crashes.
  • Classic Scoring won't load and crashes.
    My Classic scoring system is crashing when trying to load up. The program is generating an error that reads, "Failed to create empty document." Does anyone have any suggestions that might help?
Qubica BES-X Lane Advertising
Ball Damage at my wits end
GS-X table bolts/stud
Other that...
1:1 shaft wear
