Score table to Front desk notification signal button
  • Score table to Front desk notification signal button
    Looking into inoperative call button on Vantech score table, determined button switch not jobbing by shorting leads on it which set off beep at the desk. After contact cleaner was no help and considering Emery pad to contacts like motor start relays like, saw the (nicely exposed) switch contacts not getting touched. The black plastic push button uses internal tabs that wore down so not pushing the metal prong deep enough. Found rotating it 90 degrees gets to use its other slot for proper function. Next step would be shims under the prong if tabs are gone. Save that new switch for later. Wonder how many tossed for this reason?
Detector Rod Adjustment
The New Brunswick NXT
