ComScore/Vantech rebooting.
  • ComScore/Vantech rebooting.
    I have one pair that started booting oddly.
    Would finely boot up and work fine.
    Now.... it's booting over and over..finely goes to stand alone.
    Works for a bit then goes back to rebooting and rebooting.
    Help.........
    I would suspect the PSU on its way out. Low voltage causes this.
    If you grab a keyboard plug it in and go to the Bios you can check the 5v and 12v readings to verify they're ok.
      Got it figured out......
      John got back to us and narrowed it to the communication board....
      Unplugged it and it booted up quick as ever.
        Thanks for posting back on the solution. I'll remember that one.
        Before and After
        Pins getting gouged
