Matrix Box stuck on Loading screen
  • Matrix Box stuck on Loading screen
    During our leagues today, the Matrix box on 7-12 overheated and rebooted itself, it does this ALOT and the other 2 boxes never overheat, but this time, its frozen on the "Loading" screen on all 6 lanes and never gets out of it. Tried rebooting from the box and shutting off the breaker to all 3 boxes and TV's and restoring power, the boxes on 1-6 and 13-16 loaded up fine and fast, but the box on 7-12 still is stuck on the boot up screen.
    Luckily we had a spare box never used and replaced the box with this one, but this box has a 2004 firmware on it(normal box had a Feb 2008 firmware on it) and it has the problem to where the "Play" and "Clear" button images are swapped on the End of game screen, and so people hit the Clear button instead of the Play button and it turned off the lane. I cant update any of the boxes because there is no room on the desk computer for some of the files it needs to get. One more thing I noticed is that with the spare box, it also takes a while for it to boot up compared to the other 2 boxes.
    Any help to get the original box to boot up again would be appreciated.
    To diagnose the startup issue you'll need a keyboard and monitor to plug directly into the box. The monitor must be plugged into the VGA plug on the box, not the VGA splitter cables. The box is just a pc with Windows XP on it so you will see the Bios boot screen and XP loading screen. You might find it is PSU related and/or a dead bios battery. Two likely problems are the Bios battery being flat which means the bios can't remember settings after power cycling. The other is the PSU not providing enough power to the hardware for it to stay running. Both problems are fixable.
    The slow booting of the new box will be the default bios setting that has it test the RAM three times versus none, the latter is what the others would be set to. This doesn't mean there's anything wrong with it though.
    To update the software on the new box you should be able to push the files from P drive. When you say there's no room on the desk computer for the files do you mean P drive is hosted on that computer? Or do you have a NAS for P drive?
      Alright, I can go see what I can do in a few days. I believe the P drive is hosted on the computer.
        Update- Turns out it was a faulty power supply, after replacing it the box booted up fine.
          Awesome! Thanks for the update.
          Pins getting gouged
