Comscore dose not Go to Second Ball.
  • Comscore dose not Go to Second Ball.
    I have a lane that will not go into the second ball on the Computer Score. We have matrix. It just keeps putting the score into the First Ball of the first frame. The Machine is doing first and the second ball fine.
    Frame sync is enabled.
    You must have a connection to the second ball light from the MIB to use this feature.
    Broken key
    Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
    Anyone wanting to have a guess at
    A) Which...
    MONITOR COLOR ISSUE!!
    Pin spot is off
    4" PVC BOW EXTENDERS
    As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
