Matrix pair randomly shifts pin-spots.
  • Matrix pair randomly shifts pin-spots.
    On lanes 7-8 on Matrix, it will all of the sudden shift the pin-spots on the camera by a little bit on both pairs, causing misscores on the pair, and this can happen one or two times a day, or not happen at all on another day. The camera is fully secured and does not move at all.
    I've had that happen too. You could have a loose lense and/or loose internals. You can open the camera and ensure the internal structure is tight.
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
