How much are Automatic Scoring systems going for these days?
  • How much are Automatic Scoring systems going for these days?
    Things have changed a lot since I was in this arena 25 years ago. We had one 386 computer running three screens/keyboard/grabbing a frame of video to count pins/ and some opto relays to sense fouls/and other opto relays to reset the pinsetters. If I remember right it we sold ProScor for about $2k a lane.
    I'm thinking of writing a simple scoring system using Raspberry PIs, but if there is no profit to be made then it is not worth the time.
    James Little
Detector Rod Adjustment
The New Brunswick NXT
