random cycling on a sync system
  • random cycling on a sync system
    anybody out there that has had the sync system for a while that has had this problem of when a ball is thrown on one lane the other will cycle too
    Check ball detects for cross talk.
    If thats not the problem, try swapping the peripheral controller.
      wookie8662 tried that and put and put a new peripheral on and still the same thing and also switched it a box off a good working pair still same thing we have a new guy in the front that like to push buttons i think he may have screwed up the program and on top of that we had some new updates to the last update we got the same pair i had to change the address on the peripheral control box but we did have any problems like this till new person started working here i only had the once in a while sensor adjustment
      MONITOR COLOR ISSUE!!
      Pin spot is off
