Easiscor - twelve strike system
  • Easiscor - twelve strike system
    Is there any other easiscor guys out there??
    going to Orlando trade show next week to look at the current version of the twelve strike system and any others that are set up.
    While I like the look of the Quebica system, they tell me theirs will do all the same stuff just easier and cheaper than anyothers on the market.
    Any opinions
    Re: Easiscor - twelve strike system
    I'd be more concerned about support after the sale. Will easiscor be around for a while? Qubica may cost a bit more, but they seem to have a lot going for them.
      marty, stay away from easi-scor and twelve strike!!!! the system is built cheaply, tech suport is almost non-existant, and replacement parts are insanely priced. we had easi-scor (before heddon and twelve strike split) all 24 of our overheads were different colors and we tried getting tech support to fix the problem. they said that there was nothing we could do...so we pulled the system out and installed qubica. this is by far the easiest system i have worked with tech support is great, i get replacement parts in no time. it's a great system you'll love it. get in touch with me if you have any further questions about either system
      Cloth: ShamWow!
      Machine: Johnny 5
        I worked for ProScor a long time ago.
        In the old easi-scor system, there were some adjustments that could be made on the monitors to get them to be the same color. On the old hantarexs the adjustments controls were on a cord that hung down so that you could see the picture while adjusting it.
        James "Randy" Little
        MONITOR COLOR ISSUE!!
        Pin spot is off
