mendes front desk
  • mendes front desk
    I'm trying to find a Mendes front desk scoring manual. Or at least if someone could tell me if there is a way to check how many games have been bowled in some kind of report.
    Re: mendes front desk
    There is a way as I used to get a report, let me look for the manual and get back with you.
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Loading...
    MONITOR COLOR ISSUE!!
    Pin spot is off
