Mendes help
  • Mendes help
    Looking for the install guide, schematics, repair manual, or anything that is related to the Mendes system.
    The front desk version# is 3.1c Build# 3137k if that helps.
    Having lane hard drive trouble, which takes out 3 pairs.
    New to Mendes, so I need to start learning.
    Thanks
    PinCup
    Re: Mendes help
    i will scan in and send you what i have but it is very little help with the front desk. if somebody else has anything I would like copies also.
      Re: Mendes help
      Anything would help.
      When we looked at the center, only 4 of 16 lanes worked.
      I learned yesterday that 7-12 is up but 1-6 is still down.
      It's blowing hard drives.
      Anything you have is greatly appreciated!
      Send to; [email protected]
      Thanks,
      PinCup
        Re: Mendes help
        Thank you smurtland,
        Originally posted by smurtland
        I got this today it should contain all you need.
        ftp://ftp.qubicaamf.ca/Public/Scoring/
          Re: Mendes help
          Pin Cup,
          The hard drive has to be addressed correctly. You cannot take the power supply/hard drive from one set of six and move it to the next with out readdressing the IP code. Not a bad system other than when you loose one you have to shut down six to work on it. I had the system in California and never really had trouble with it as long as you opened up the main consoles monthly and blew them out and kept them clean and the cooling fans in good shape. Heat will shut them down everytime I think.
            Re: Mendes help
            What might cause the hard drives to lose their boot files?
            Local guy and his son have discovered the boot folder empty.
            Any ideas?
            PinCup
              Re: Mendes help
              this is a great post for us folks stuck with Mendes and no info at all. Thanks for posting the link! The info is still there.
                Re: Mendes help
                Ok sorry I may have jumped the gun a little as some of the info doesn't seem to come up. That isn't the fault of the person that posted the link though.
                It is of course a couple years old from what I see.
                MONITOR COLOR ISSUE!!
                Pin spot is off
